Temperature gauge wacko...
Old Nov 6, 2021 | 05:33 PM
Jemm01's Avatar
Default Temperature gauge wacko...
Guys, having some delimma with my 98 ek... while driving at about 45mph with ac on... headlights on... my temp gauge suddenly goes from normal to 3/4... suspecting of overheat i went to the side to check... seeing nothings wrong... coolant reservoir is ok... rad cap intact... hoses intact... i observed a bit more... til the condenser fan stop means the ac automatically went off then on again... i notice once tge condenser stops the temp gauge goes up... thwn when it runs again thw needle goes down... any idea where could be the problem? Any help would be appreciated...
Old Nov 6, 2021 | 11:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Temperature gauge wacko...
Air trapped in the cooling system. Re-bleed/fill the system properly.
Old Nov 10, 2021 | 05:38 PM
Jemm01's Avatar
Thanks... I will try to re-bleed the system...
95lover
Jun 23, 2021 04:46 AM
bwiissofly
Jun 26, 2013 01:17 PM
-BlueGSR-
Dec 16, 2002 10:35 PM
Rguy
Jun 4, 2002 08:41 PM
