Rear struts something looks wrong
Old Oct 30, 2021 | 03:02 PM
Ttew's Avatar
Default Rear struts something looks wrong
Hi, my first post, could not find this on search. My daughter's 1990 GS hatchback was lowered by prior owners, the car squeaks a lot, when I tried to track it down found the pix attached. The rod on the strut is rubbing against the cup, there are even metal shavings. This is on both sides. I'm a neophyte but it looks like a bushing is missing or the struts are just installed incorrectly. Any advice is appreciated, thanks.
Old Nov 1, 2021 | 06:17 AM
Ryanthegreat1's Avatar
Default Re: Rear struts something looks wrong
Wow. Some people....
You are missing the rubber bushings for the top hats. With the amount of material worn away you might want to find complete tophat replacements.
Old Nov 1, 2021 | 07:18 AM
Ttew's Avatar
Wow, thanks! Yeah, that is what I thought, but wasn't sure if this was some sort of modification, or just a big miss by the prior owners. The cover boots were loose in the wheel well.... I saw the schematics on line and it shows what you're saying. Really appreciate the answer, RYANTHEGREAT1! I will take your advice, the metal is pretty ground down in a couple of spots. Stay tuned, my guess is there will be more of this to come, holy cow!
ITSUKA
Aug 17, 2005 04:09 AM
ekdriven
Mar 18, 2005 03:55 PM
FuC]{eD_OvEr
Mar 2, 2005 01:35 PM
ekb18c
24
Feb 18, 2003 05:13 AM
