Fuel pump not priming. 92 eg
Old Oct 27, 2021 | 02:14 PM
redbull99's Avatar
Default Fuel pump not priming. 92 eg
I have a 92 gsr eg that has sat for 5 years. I also changed the fuel pump, fresh gas, oil, and brand new battery as well. I tried to start it but the fuel pump is not priming. When I jump 5 and 7 on main relay nothing when I jump 1 and 7 fuel pump primes. Does this mean it's the main relay?
Thanks
Old Nov 1, 2021 | 02:03 AM
ShadoeFax 86's Avatar
Default Re: Fuel pump not priming. 92 eg
My first step would be to check the fuel lines for any leaks or cracks in lines. Do you smell gas when trying to start it? Did you change the fuel filter as well? I would change it if not & it is really easy to install backwards because of how similar both ends are. What happens when you turn key?
Old Nov 11, 2021 | 02:36 PM
redbull99's Avatar
Problem solved. Sent my ECU to Burton-racing and they did bench test. Although the only thing that was burnt was Q31 transistor, They were kind enough to replace IC17 Chip even though they said it wasn't burnt, but just incase because i explained that my fuel pump was not priming; and Sure enough fuel pump primes now.
MU3RT3
Feb 23, 2016 06:09 AM
Hypermax
17
Aug 13, 2011 04:44 AM
Volfrosh88
Aug 16, 2006 12:17 PM
