smog for calif problems
Old Oct 23, 2021 | 09:48 AM
nivekracing's Avatar
Default smog for calif problems
hello
I have a 1994 accord ex with 282000 miles
tried to smog it and failed
about 12000 ago I did the head gasket
15mph 1664 rpm
%co2 meas 14.9
%o2 meas 1.0
HC (ppm) meas 188 max 61
CO% meas 0.42 max .51
NO(ppm) mean 663 max 490
25 mph 2653rpm
%CO2 meas 15.2
%02 meas 0.1
HC (ppm) meas 33 max 36
CO(%) meas 0.12 max0.49
NO(ppm) meas 156 max 730
my question is where do I start
does timing cause a big difference ?
valve adjustment?
before I went to smog changed the oil and filter
cleaned air filter k&n washable
plugs
and drove around for 15 minutes before taking the test..
any advise would be helpful
thank you
NEW INFO
I found an exhaust leak at the manifold to down pipe connection
would that cause the high numbers
also did a compression test 135psi all 4
Old Oct 26, 2021 | 09:02 AM
ag_ghost's Avatar
10 Year Member
Default Re: smog for calif problems
No CEL?
FaLKoN240
Feb 4, 2015 10:55 AM
California98Civ
Southern California
Sep 1, 2014 09:54 AM
efmk4
Jul 30, 2012 05:30 AM
