Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Headlights go out when brights turned off
Old Oct 13, 2021 | 11:28 AM
murrayjs13's Avatar
Icon5 Headlights go out when brights turned off
I have a 2005 Civic. Just yesterday my wife noticed that, when she turned off the brights, the headlights went out. (We live in a rural area so brights are important.) Today she and I tested it while in the driveway. Sure enough, if she turned on the headlights, then the brights, then turned off the brights, the headlights went out as well.
Interestingly, if a turn signal was on when she turned off the brights, the headlights stayed on. L or R signal made no difference.
Any suggestions as to the cause, and repair, are appreciated.
Old Oct 14, 2021 | 07:10 AM
NDNV's Avatar
Default Re: Headlights go out when brights turned off
I'd say that sounds like a faulty combination light signal switch (i.e. faulty headlight stalk). I've replaced mine but mine was all loosey goosey. You can test the switch for continuity according to a switch position table before replacement.
Old Oct 14, 2021 | 08:31 AM
murrayjs13's Avatar
Thanks. I suspected something like that.
Old Nov 2, 2021 | 09:21 AM
1992BB2's Avatar
I second this. The combination switches on the 7th gens are notorious for doing funky things as they wear out. I had to replace my switch in my 2001 not long ago because it wore out and started acting up.
Old Feb 17, 2024 | 01:44 AM
Yeahman's Avatar
Do you have any other ideas.0I have changed the control and I still have no low beams
Old Feb 17, 2024 | 05:49 AM
Ryanthegreat1's Avatar
Are the bulbs burned out?
Old Feb 17, 2024 | 03:10 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
And then start working your way backward from here…
cplcueball
Aug 7, 2012 04:15 AM
honda_boy23
Mar 14, 2010 09:13 PM
cimo463
Apr 2, 2008 01:18 PM
Jaypee
Jan 1, 2004 01:14 AM
