+ oil pressure wire?
That’s exactly what i was thinking. Guess i could use the - signal to activate a relay to send +12 to the unit. Just trying to minimize my number of relays I’m having to cram under the dash and wanted to check to make sure i was seeing things correctly. On a second thought if it needs a +12v signal, i could simply grab the wire off the coil that is energized when running.
xxh23fuzionxx
Aug 25, 2003 07:24 AM
