Wiring in fueltech ecu/guage on 1997 civic ek
I am wiring up my crank and cam hall/vr setup and am a bit confused on how to go about doing it for a single cam d16 civic. I know the y7 has a sensor on the crank pulley and distributor for timing. Does anybody have a pinout diagram relating to this or information? Thank you kevin!
I did alot of reading and correct me if I'm wrong but, hall sensors are outdated/aftermarket crank position sensor setups and vr is more modern factory sensors. I am assuming our cars use a vr sensor only?
