Steering Column Question
Old Oct 11, 2021 | 10:45 PM
jafferkhan's Avatar
Default Steering Column Question
Guys, this is my first civic, and I needed to ask whether or not I can have the steering adjusted because it's way too low for me. I showed it to two mechanics, one said the entire column will need alteration, the other said it'll need a new column. I read somewhere here that I can install a Tilt from an Si or Dx. Attached a photo of the steering after I opened it up. Can this be adjusted? there's some space between the column and the instrument cluster as well.
Old Oct 12, 2021 | 04:30 PM
Tyson's Avatar
Default Re: Steering Column Question
CRX si (maybe also the Civic Si) has a tilt column you should be able to replace if you have everything and switch over the ignition.
Old Oct 14, 2021 | 02:08 PM
jafferkhan's Avatar
Thanks man. Will try getting one then
DemonIntegra94
Jun 1, 2017 07:31 PM
hard_boiled_EG
Jul 16, 2009 10:35 AM
Non-Vtec101
Suspension & Brakes
12
Apr 4, 2007 01:17 PM
vtec_crazy
Aug 29, 2005 07:05 PM
