Sputtering on Acceleration issues
Old Oct 11, 2021 | 04:37 PM
nathanh510's Avatar
Default Sputtering on Acceleration issues
Hey guys, so today I took apart my IACV to check to see if it was clogged up and dirty, sure enough it was. So i cleaned it, put it back on, only thing i was worried about was if i put the hoses in the right spots on the iacv. i’m pretty sure i did this correctly. but now after i cleaned it with carb cleaner, it will sputter once i give it a little bit of gas while driving. it also is idling a little bit lower than what it was before. I’m not really sure what I did wrong. I followed along a video because I had not messed with that part before. Just worried i messed something up. please help.
Old Oct 13, 2021 | 08:32 PM
nathanh510's Avatar
Default Re: Sputtering on Acceleration issues
Update: I found the root issue of the problem causing my sputtering. I found a vacuum leak coming from my intake manifold gasket. It was kind of hard to really hear the air seeping out because of my exhaust so hence why I didn't think to check for a vacuum leak.
Prophet1990
Oct 21, 2011 10:25 AM
herecomesfreddy
Honda Motorcycles
May 31, 2009 05:30 PM
importtuner1413
Nov 21, 2008 08:04 AM
pilsung97EXturbo
Mar 22, 2007 02:42 PM
Turck
Oct 31, 2004 08:18 AM
