1997 Honda Accord 2.2 vtec spark but no start
Old Oct 10, 2021 | 02:04 PM
devon1231's Avatar
Default 1997 Honda Accord 2.2 vtec spark but no start
Car has great spark and getting fuel but won’t crank all fuses and relays are good ik my ignition lock cylinder is bad but I don’t know if that has anything to do as it turns over really strong I’m getting good fuel and it wouldn’t start with starting fluid in the intake, thinking it could be a distributor rotor, help ?
update: getting fuel from the pump but not thru the injectors, took the fuel line off and it’s got hood pressure and fuel, all 4 injectors aren’t spraying at all. Reading about the ecu possibly losing a ground or being fried and the fuse and relays under the dash but my ignition lock cylinder is bad and when I play with the key a lot it sounds like it’s firing off but it jus won’t spray long enough to make fire not sure what to do
SentinelK151
Aug 6, 2017 08:42 AM
leflore
Sep 1, 2016 05:33 PM
Bienval23
Aug 18, 2014 12:14 PM
trex352
May 24, 2012 01:48 AM
digital_cowboy
Jul 7, 2007 06:37 PM
