Suspension & Brakes Theory, alignment, spring rates....
Im in need of some help
Old Oct 10, 2021 | 09:19 AM
Jose Segarra's Avatar
Default Im in need of some help
Anyone know how to lossen the nut on the right passenger side tie rod I have a 1999 Honda civic cx and ive been battling taking off the tie rod nut but it won't budge at all ive gone as crazy as using a rope and using it to pull the wrench and the nut still won't loosen ive heard of people just using a blow torch or something and getting it real hot and then using a wrench to turn it and it would loosen right out but idk any ideas?
Old Oct 10, 2021 | 12:59 PM
Ryanthegreat1's Avatar
Default Re: Im in need of some help
You need a longer wrench or an impact gun. Make sure you are going in the correct direction and not making the nut tighter.
Old Oct 11, 2021 | 01:52 PM
Tyson's Avatar
tie rod NUT? are you turning right direction? this is one i always have to think about. nothings reverse threaded, but depends on which direction youre looking it messes with your head.
i lock the tie rod with an open wrench against swaybar or whatever it can, so it doesnt rotate with the nut.
and if i need more torque on the open ended wrench of the nut, use another open end wrench to lock in the outer end and give it a good push (not kick, you want a controlled push) with the leg.
Old Oct 12, 2021 | 11:09 PM
BJ Mann's Avatar
Which nut were you talking about?
99 Civic CX Tie-rod
Peeb
Honda Civic (2001 - 2005)
May 31, 2012 03:47 PM
91GEDHATCH
Jun 19, 2010 07:56 PM
teler86
Jan 25, 2006 04:47 PM
1LEWDh22
Dec 22, 2005 12:44 PM
xxxmikenicexxx
May 12, 2005 08:00 AM
