Crank no start, spark ignition coil not at leads
Hi I need some help 😊 I have a 98 Honda Prelude Si. I have recently changed over the distrubtor as it would crank but not start. After changing distrubtor over I have spark at coil but not at leads. I have tested all fuses. I can hear the fuel pump but since changing distrubtor I cant smell fuel anymore.
I have the firing order correct on the distributor cap
Do I need to do the timing on the distributor otherwise it will not start? Or will it just run rough?
Thanks Cam
Thanks Cam
JodiP1983
Aug 6, 2020 12:01 PM
C-West Civic
Jun 6, 2017 05:40 PM
Herbie
Apr 21, 2010 09:57 AM
