Suspension & Brakes Theory, alignment, spring rates....
Do I need to replace the boot on this tie-rod end ball joint now?
Old Sep 30, 2021 | 06:45 AM
BJ Mann's Avatar
Icon7 Do I need to replace the boot on this tie-rod end ball joint now?
My 13-year-old Acura TL Base is at 100k miles now, had it for the last 6 years and 50k miles. Just noticed both tie-rod end ball joints had some grease leaked out from the bottom of the boots. Jacking up front tires and wiggling at 3 and 9 o'clock felt fine. Pulling or shaking on the tie-rods by hands didn't produce any noise or movement at all. No clicking or any other noise when driving or turning. Everything appears fine except the leaking grease.
Should I fix the issue now by cleaning the old grease out, repacking fresh grease, and installing new boots? Would this repair significantly extend the life of these ball joints? Or do I just wait for them to start making some noise or having some play who knows when maybe even years later then I'll replace both tie-rod ends when the time finally comes? :-)
Right tie-rod end ball joint
Old Sep 30, 2021 | 09:45 AM
Tyson's Avatar
Default Re: Do I need to replace the boot on this tie-rod end ball joint now?
you did the right diagnosis. better would be to have someone turn the steering wheel and you put your hand over the balljoint to feel for play.
but just the grease alone leaking is totally normal. i would not remove the balljoint just to repack.
Old Sep 30, 2021 | 08:01 PM
Ryanthegreat1's Avatar
I agree. Should probably just leave those alone.
2012crvChick
Honda CR-V & Element
Feb 17, 2021 12:30 AM
jhelmick1
Jan 9, 2008 05:09 PM
mod88
Jan 25, 2005 02:31 PM
thatdamngood
Mar 14, 2004 07:46 AM
