Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
What can I spend $4000 on for maintanance?
Old Sep 29, 2021 | 02:22 AM
PookieNumNums's Avatar
Default What can I spend $4000 on for maintanance?
Good day everyone
I own a 2009 4 door Honda Civic with 57,000 miles.
I know nothing of cars. It's in fantastic no problems shape. In January of 2023 I will have $4000 to play with. Now I'm going to try and spend as little as possible on the vehicle but I also want to do any maintenance that I should have done.
I keep up with oil changes quite often.
What are some things I could do to ensure long life?
Thank you for any suggestions. I want to keep this vehicle in awesome shape.
Old Sep 29, 2021 | 06:22 AM
Ryanthegreat1's Avatar
Default Re: What can I spend $4000 on for maintanance?
Tires, battery, brakes, and fluids. Assuming none of that has been maintained along the way.
Professional detail and a ceramic coating would go a long way towards preserving the exterior.
Old Sep 29, 2021 | 10:58 AM
av911's Avatar
Early 2009s were also victims of the cracked engine block, check your VIN.
Old Oct 7, 2021 | 10:04 PM
highschooler's Avatar
I’d do a transmission fluid change, coolant fluid change, and an alignment first, then see if other parts are damaged or worn out next.
elzocalo
Feb 9, 2020 03:17 PM
Ricey McRicerton
19
Sep 22, 2010 12:12 PM
DeSeNt
11
Sep 25, 2008 10:56 AM
accordy
Nov 7, 2004 07:59 PM
