!998 Honda Accord 4 Cyl Oil Leak
Old Sep 28, 2021 | 10:20 AM
jmerritt10340's Avatar
10 Year Member
Default !998 Honda Accord 4 Cyl Oil Leak
I have an oil leak that I can't find the source. I got underneath and oil is across the bottom half of the engine. Checked the new valve cover gasket and it is OK. Oil filter is also OK. Any ideas are appreciated.
John
Old Sep 28, 2021 | 03:38 PM
nicolaselias's Avatar
Loved
Community Favorite
Default Re: !998 Honda Accord 4 Cyl Oil Leak
Crankshaft seals potentially? Only way to know for sure is to degrease the engine and see where the oil is coming from.
Any leaks around the distributor?
Old Sep 28, 2021 | 03:49 PM
99stockcivic's Avatar
As said above, clean and then check for oil under the distributor cap. It's also possible to find oil on the back of the engine coming from oil PCV valves and such. Oil pan leaks also happen.
Finally, are you sure it's oil? Power steering, transmission, and other areas under there can leak.
Post pics, might help with identifying
collinsbrianw
Dec 3, 2017 07:23 PM
HndaOwner
May 10, 2014 04:24 PM
BradyNZ
Mar 17, 2014 09:57 AM
95halx
Sep 5, 2012 12:35 PM
SuperChic[k]
Jan 21, 2008 09:14 PM
