ECU
hello guys,
i have a honda civic 07 hybrid. i have changed spark plugs and cleaned throttle body. but after 2 days the check engine is on.
Do i need to reset the ecu following the replacement of parts? If yes what do you recommend? Remove ecu fuse or remove battry cable?
If it’s really only misfiring on one cylinder than more than likely it’s your ignition coil on that cylinder. Because if it was fuel related, well it could be your fuel injector on that cylinder but it’s less likely than the ignition coil. Probably isn’t your fuel pump or you would get misfires on more cylinders.
Oliver Koelsch
41
Dec 8, 2020 09:02 PM
