RSX Header that will clear K24 Swap
Old Sep 22, 2021 | 10:38 AM
Nisif's Avatar
Default RSX Header that will clear K24 Swap
Hey All,
Looking for a bolt on header that will clear the K24 added deck height on a 2005 RSX Type S... Can anyone confirm if the DC Race Header clears the front sway bar without modifications? Or any other header that doesn't use a rattle prone slip fit design? Thanks
Old Sep 22, 2021 | 08:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: RSX Header that will clear K24 Swap
I just did a K24A2 swap on a 2006 RSX-S and used a PLM K24 (V2) header with it... worked perfectly with the stock sway bar. My own RSX-S has a K24/20 mildly built engine and I am using a PLM K24 (V1) header which made contact with the OE sway bar on occasion during hard acceleration or hard braking... installed a 2006 Element front sway bar with aftermarket end links and everything is fine.
Old Sep 23, 2021 | 10:12 AM
Nisif's Avatar
Ok good to know, I checked out website, it doesn't state version 1 or 2 but this one lists for \ RSX.
Did you have any annoying rattles or leaks with the slip fit design? Thank You
Old Sep 23, 2021 | 09:03 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That's the one. No problems so far... I have had it for nearly four years and 35K miles so far.
Old Sep 24, 2021 | 11:14 AM
Nisif's Avatar
Awesome, good to hear, you'd the man. Appreciate it
thakid
K Series
Jun 25, 2012 09:28 AM
VtecKiDD
Performance
198
May 24, 2011 07:23 AM
supwitu
Jun 4, 2010 05:20 AM
taggart_lumpy
May 28, 2006 02:33 AM
ThinHoanG
Feb 28, 2005 12:28 AM
