HELP! Rpm idle getting stuck at 2k until revved
Old Sep 21, 2021 | 06:01 PM
Timothy Yhtomit's Avatar
Default HELP! Rpm idle getting stuck at 2k until revved
Hello I got a 91 hatch wit a b20, skunk2 intake manifold and recently I swapped out the stock throttlebody to a aftermarket 70mm. The new throttlebody doesn’t feel like it’s sticky at all so it’s not getting stuck and the tps is calibrated to .50 when closed. I’m using a 94-01 integra throttlebody cable, I don’t know if I should swap to the 90-93 integra cable. Will that make the difference I need? If do please let me know.
For some reason when the car is warmed up and I’ve been driving around for a little while the rpm will get stuck at around 2000rpm when im coming to a stop and in neutral or when I clutch in, then I would have to press gas to rev it a little so the rpm would drop super low then it goes back to normal idle around under 1000rpm. Kinda lost help
Old Oct 8, 2021 | 07:31 AM
neutronscott's Avatar
Default Re: HELP! Rpm idle getting stuck at 2k until revved
I'm still new at the car stuff but since no one else has any suggestion,
Do you still have an IACV? Have you checked that it does not stick
Old Oct 8, 2021 | 05:55 PM
Yeah, ever car need a IACV. And it's still a good one, I remember cleaning it out not too long ago but maybe I should reclean it lol thanks for the input and good luck with the car stuff!! Headaches at times but all worth it in the end!!!!
Blude'
Feb 16, 2010 10:00 PM
gsrjdm00
Feb 16, 2009 09:48 PM
Bizarre
Sep 6, 2007 09:40 AM
d16vteceg
24
Jun 25, 2006 05:47 PM
BeanRacer
Jan 10, 2002 02:29 PM
