Denso Iridium Spark Plugs?
I have a 2000 Honda Prelude SH and i want to put in some plugs, wires and igniton. I want to go with Denso Iridium Spark Plugs...do these come pre-gapped since they have them for particular applications or do I have to gap them myself?
I also want to get NGK Performance Wires..what do you think..are these good??? Also i want to get a MSD 6AL Ignition Pack...what kind of ignition coil should i get???
What do you guys think of this setup??? All suggestions will be taken into consideration. Thank you.
are you sure???? well then if thats the case then what should i get??? im gonna purchase headers and a cat so what else is there left to do???
unless your going Turbo, supercharger or nitrous the msd ignition is going to serve to much of a purpose. What other mods do you have? With the name Mugenpoweredlude, i am assuming your going to get the Mugen Header. Carsound makes a nice cat.
I'd go with the MDS 6a, wires and the Denso Iridiums. (In my 94, I have the 6a, blaster 2 coil and the Iridiums) Much better throttle response and feels quicker off the line. I emailed Denso about the plug gap because MSD states a .050 to .060 gap when using their Ignition. They said to go ahead and increase the gap because it comes with a 1.1mm gap for the Honda engine.
Well the moogen headers made a decent gain on my most recent h22a4. Limited really by the final 2-1 collector due to ground clearance. Also threw on a 6al w/ matching 8.5mm wires and ngk coppers. No gain off the bottle but it was free and replaced a crapped out factory unit. Then again, no real gain juicing either... I'd say keep the stock headers, get a cheap cai, open up the exhaust and look into a set of skunk2 cams. Can't wait to slap in a set of stage2lo/stage3hi cams.
BoroDB8
Apr 20, 2002 08:24 PM
