After swap from automatic machines to mechanics, check P0700 and P1768 are lit, P2P a
Old Sep 18, 2021 | 07:22 AM
maksick's Avatar
Icon5 After swap from automatic machines to mechanics, check P0700 and P1768 are lit, P2P a
Hello everyone, there is a Honda civic 6 coupe. Previously, there was a
automatic, the former owner swap on the mechanic, swap badly, leaving the native P2P brains with all the ensuing problems, automatic transmission errors burned, idle speed floated, reverse gear did not work. I did the idle ones, in the break of the black wire with a blue strip, a 10 Ohm 5 watt resistor, I made a reverse gear, but I can’t fix the automatic transmission errors. For the place of solenoids A and B (Solenoid connector, this is a Yellow wire and a Green wire with a Black stripe, I soldered to them according to a resistance of 15 Ohm, 2 Watts, twisted the second ends of the resistances together and threw them to the ground) As a result, we have two errors in automatic transmission, what else missed?)
heathen heathen
Aug 25, 2019 07:15 AM
cheggie
Dec 15, 2011 11:36 AM
stkinge
Jun 23, 2009 04:14 PM
eg9 typeR
Aug 30, 2006 03:21 PM
