2013-2017 Accord EPS rack q's
Hi,
I'm looking to do an accord eps powerer rack swap into a non-honda vehicle. I had some questions maybe someone can answer (or a manual w/ schematics someone can point me to).
I'm looking to find out
- What the dimensions of the rack are (essentially from tie rod end to tie rod end) and how fat it is, roughly
- What signals are required at a minimum for the control unit to work - just engine speed and vss?
a) are they CANBUS messages or straight signals from the sensors?
Rack on that late of a model is going to be CAN bus. With no CAN communication the rack will default to full assist and be awkward at speed. And the controller is separate from the rack.
Other than that just supply power and an on signal. I do think they have a 70 amp fuse to run the rack.
ChelseaG
Honda Accord (2013 - 2015)
Dec 8, 2017 11:24 AM
