2004 honda civic dx coupe 1.7l sohc
i have checked my sensors and all are good. im still not getting spark. also found my timing to be off 1 full turn of the crankshaft. my question is.... would it being out of time cause it to not get spark? if not..... what could be the issue? how do i check to see if im even getting power to my ignition coils? which hole on the plug do i insert the test light into? please help!! thanks ya'll
Check for injector pulse , no spark and no injector pulse is probably the crank sensor . There's also a fuse under the steering column ( #10 ? ) you can check If it ran before your timing would not be that far off . I would say no spark means no power to the coil overs .
