What enigne intake manifold gasket is this? - Bisimoto
Hi everyone,
Been doing a bit of a clean up and came across this genuine Bisimoto heat-shielding intake manifold gasket (still sealed). At the time when I bought it, it was supposed to be for the F22/F20 SOHC but it didn't fit mine, so I put it aside and forgot about it. I emailed Bisimoto asking about it later and they of course didn't reply.... Typical
Do any of you know which 90s Honda engine / intake manifold this fits?
Re: What enigne intake manifold gasket is this? - Bisimoto
Thanks for the quick reply Ghost. It does indeed look like the F22A intake manifold gasket.
Could swear I specificed it was for a F20B2 (same head as F22B2) when ordering, and they sent this. Tried arranging an exchange at the time but it never ended up happening.
I was on Bisi's site yesterday trying to browse to see if they had any photos of this or similar gaskets, but I realised they have since abandoned the honda scene completely.
Anyway I just found an old pic of my actual (16 year old at the time) intake manifold gasket from the F20B2 that I had to scramble to find one to finish my build. Was not a happy time, cause I also had issues with valve spring coil bind with a Bisimoto cam, despite it being rated to work with factory valve springs. Ended up buying bisimoto's valve springs with a mild discount but then left the country and never got around to finishing the build. I'll do it one day, but you know how these things go. Accord is working fine, so haven't felt compelled to pull down the engine again unless it happened to need a head gasket or something.
