F20b stock ecu or switch to obd1
Old Sep 14, 2021 | 03:57 PM
Crucialjk's Avatar
Default F20b stock ecu or switch to obd1
I own a 98 honda prelude and I swapped in a f20b but since I'm using the h22a ecu it runs well but it is running rich, I kept basically everything from the h22 except the engine and transmission. I just need some help deciding whether to buy a f20b ECU or switching to a chipped obd1? Also if I went obd1 I see people saying it's a plug and play and others say I need to replace the dizzy, and other pieces for it to work what do you guys think?
Old Sep 14, 2021 | 08:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: F20b stock ecu or switch to obd1
Nothing needs to change in the engine bay if you switch to an OBD-1 ECU with a tuning solution (like Hondata s300). A "Chipped" ECU is just a HOPE that it runs correctly... getting it tuned insures it runs correctly.
Old Sep 14, 2021 | 08:07 PM
TimiK's Avatar
chipped obd1 is not plug and play since you need to get it tuned
Old Sep 15, 2021 | 09:59 AM
ross2004's Avatar
OBD 2 -> 1 jumper harness at ECU, OBD 1 ECU with Hondata (or similar), tune.
Ek9_Cuhzz
Northwest (Sales)
Jul 15, 2010 12:07 PM
Jap_Spec_Imports
Aug 10, 2009 07:11 PM
