B20 swapped 91 integra ecu
Old Sep 14, 2021 | 05:58 AM
nadims23's Avatar
Default B20 swapped 91 integra ecu
Recently got a b20 swapped 91 gs integra, owner did nothing to the ecu, just plopped the engine in. It has a stock obd0 ecu and seems to need an o2 sensor and a iacv sensor/plug. Would it be best to convert to obd1 and tune, or stay in obd0 and tune? What kind of o2 sensor+iacv sensor would I need in either case?
Old Sep 14, 2021 | 08:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20 swapped 91 integra ecu
How would you tune it using an OBD-0 ECU ? You can use a single wire O2 sensor if it is mounted on the front of the header close to the cylinder head. You will need a 4-wire O2 sensor if you mount it at the back end of the header behind the oil pan. IACV sensor works very similar regardless of what year engine it comes from. Distributors are different from OBD-0 to OBD-1/2... so if you are OBD-0 now and intend to convert to OBD-1 for a tuning solution, you will need an OBD-1 or OBD-2A or B distributor as well. The only differences between these is the distributor plug and whether that plug has a tach signal wire in it or not. Any can be properly wired for your application.
Old Sep 14, 2021 | 09:08 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Mind posting pics of this integra?
Also, you can keep it stock with the PR4 ecu. It might run a little lean but my bro never had a problem with his setup.
Yuta
Oct 8, 2018 06:16 PM
BokudenNYC
14
Aug 4, 2009 07:29 AM
91civichatchCrX
Nov 22, 2005 01:54 AM
