Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Civic Si flooded in NYC area help
Old Sep 13, 2021 | 10:39 AM
SiGuy120's Avatar
Default Civic Si flooded in NYC area help
Long time lurker here….so my civic Si got flooded in the NYC area during IDA. It’s a 2007 and I would like to keep the car.
The water made it up to the dashboard. I’ve dried it out and when I put the key in the car goes crazy blinking lights wipers wiping and it won’t even attemtpt to start. I’m guessing there’s damaged ECU’s. Does anyone kno any garages preferably in westchester or northern parts of Bronx that i can tow it for it to be fixed
used car prices are out of control I would rather take the money and fix my Si than buy something else
Old Sep 15, 2021 | 08:28 PM
Ryanthegreat1's Avatar
Default Re: Civic Si flooded in NYC area help
Probably damage to a lot of things including the ECU but the MICU is probably what is responsible for the crazy lights and wipers.
Old Feb 18, 2023 | 08:58 PM
AnthNirvanaA1G's Avatar
This happened to me and I didn’t even try to start the car for fear of messing something up. Disconnect battery asap. You can try completely drying out the fuse boxes and control unit modules first. It will take some time but the sooner the less corrosion since it needs time. I sprayed everything electronics with alcohol then dried out and used dielectric grease to repel water and protect sensitive stuff (you can also spray some contact cleaner WD40)
Honder07si
68
Apr 15, 2007 04:56 PM
JDMhondaslut2
Nov 16, 2006 06:36 AM
JDM RHD eg6
Sep 23, 2006 11:57 AM
