2002 Accord V6 ECU Swap (old one was flooded)
Hello, everyone!
As the title says, I have a 2002 Accord V6 that flooded in Ida up to the ECU. I read the ODBII codes and got codes P1607 and P0560 for abnormal voltage to the ECU. I thought, no big deal, I'll go grab a used UCU from a wrecked pull-a-part and slap that in. I ran down to pull-a-part and grabbed one out of the same year/model/engine combo accord.
As you probably already know, the old key wont work any longer due to the chip in the old key. Fortunately, I was able to grab the key from the car that had the donor ECU, but of course it's keyed incorrectly.
What are my next steps? Do I get a blank key duplicated from the donor car chipped key and then get it cut to the flooded car's original key?
Thanks for your help, all, it is truly appreciated.
-Gary-
-Gary-
..additional thought.
What about running back to pull-a-part and grabbing the ignition cylinder from the same car? This would probably be the cheapest/lest expensive way to do this, no?
What say you, hive mind?
