Suspension & Brakes Theory, alignment, spring rates....
New sway bar bushings: grease?
Old Sep 7, 2021 | 08:39 AM
pontoon's Avatar
Default New sway bar bushings: grease?
Hi,
I’ve got a 2006 Honda CRV with an OEM sway bar and bushings.
With new bushings, should I be installing the bushing dry? Or should I add grease to the bushing?
The service manual doesn’t indicate the bushing should be greased.
I’m worried about squeaking if the bushing is installed dry.
And I’m worried about the bushing allowing the bar to move too much if it’s greased.
What’s the best way to install the new bushing? Grease or no grease?
Old Sep 7, 2021 | 11:54 AM
Tyson's Avatar
Default Re: New sway bar bushings: grease?
i've never greased or found grease on an OEM rubber bushing.
i dont suggest greasing them.
only poly bushings need silicone grease because, well poly sucks.
allm0torGSR
Suspension & Brakes
May 20, 2014 04:13 PM
b18LS
Suspension & Brakes
Oct 10, 2007 05:16 PM
DaZman69
Suspension & Brakes
Jan 29, 2005 07:45 AM
ragejed
Sep 25, 2002 04:40 PM
