Dented radiator fins - should I attempt repair?
Old Sep 4, 2021 | 12:49 PM
GleepGlop's Avatar
Default Dented radiator fins - should I attempt repair?
I installed a new radiator because my old one sprung a leak from a fin. Managed to dent the fins significantly on install. I can stick the tip of my finger in the dent. If I attempt to fix that spot could I just end up causing a leak?
Old Sep 4, 2021 | 01:35 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Dented radiator fins - should I attempt repair?
You'll want something like this to fix the bent fins:
Amazon Amazon
Don't use anything like a screw driver as you can damage the fins worse.
They make metal radiator fin combs that work better/last longer...just an fyi.
Old Sep 4, 2021 | 07:36 PM
Ryanthegreat1's Avatar
Leave it. Won't make an ounce of difference other than looks.
vxtirent08
Mar 20, 2008 10:36 AM
hks369
Dec 24, 2006 12:43 PM
mrlegoman
Jan 14, 2006 01:01 PM
vtecmw
Dec 5, 2005 09:44 AM
GBRacing
Aug 8, 2005 05:41 AM
