Ignition issue 91 hatch.
Old Sep 3, 2021 | 04:07 PM
MosesEF's Avatar
Default Ignition issue 91 hatch.
Hey everyone! So I just recently picked up another EF hatch. Car was originally an automatic and has since been swapped to a d16y8 with a 5speed. My issue is that the key is stuck in the ignition in the “1” setting. I’m fairly confident that there’s still an auto trans ignition interlock solenoid keeping the ignition cylinder from returning back to “0”. How would you disable or delete that? Hoping there’s a way to wire it so that it always thinks it’s in park or just ditch it completely. Appreciate any and all help.
Note: new ignition has already been installed and I’ve tried disconnecting the connector above the fuse block that goes to the solenoid but now it’s just limp, if you will, and the key is stuck in between “0” and “1”. Key will not come out still. Attached the only schematic I could find.
pepsi813
May 19, 2019 12:37 PM
JayT103
10
Aug 4, 2009 02:32 PM
deathblooms4256
Sep 18, 2008 09:57 AM
accident
Sep 30, 2005 06:49 AM
