Help in hooking up Power Steering pressure switch to ecu
Hello Friends,
My name is Sayeed from Guyana South America. I own a Right hand drive 2001 Honda Civic Ferio ES1 model from Japan. I recently swapped out my steering rack from EPS to Hydraulic. Had alot of bad days with electric changed two rack all failing years apart. The electronics and brain box goes as well. Too much cost to keep importing from England because of right hand driven also lots of knocking even after servicing rack noise comes back mths later. So I have the hydraulic model installed runs pretty good except when maneuvering to park or come out of parking the rpm drops low and even stalling engine because the power steering pressure switch not connected. Tried to follow links from online like for the Green /Black wire going on E plug pin 16 and black ground wire i tried A plug pin24, no success. Can anyone say where the two wires goes for the switch. Any help would be appreciated. Thank You.
577HondaPrelude
Sep 19, 2012 06:34 PM
Espec_rep
Nov 14, 2004 09:30 AM
