2000 EX sedan w/ d16y7, what exhaust is compatible?
00 EX sedan, just noticed it's a actually a y8 vtec head on a y7 block. are y8 exhaust kits still compatible?
Does it have the Y7 exhaust manifold as well?
Any catback intended for an EX/Si coupe or sedan will fit right. If you have the Y7 manifold/cat on it, you will need to use a test pipe to make up for the extra length where the EX/Si catalyst would normally be.
false alarm, i just noticed it's a y8 head on a y7 block. appears to have a stock y8 exhaust back to the cat, so i assume y8 catback kits are the way to go
is there any way to delete this thread?
