K24 SWAP EG PARTS LIST OEM AND AFTERMARKET
Old Aug 26, 2021 | 07:22 PM
EGGSAMICH's Avatar
Default K24 SWAP EG PARTS LIST OEM AND AFTERMARKET
Hey everyone,
Name is EGG. I've lurked all the Honda forums for the past 8 years learning everything I can. In the process of completing my second build. I'm putting in a JDM K24a (K24a2 USDM equivalent) with a type-s 6 spd non lsd into my 95 CX EG hatch. Keeping it quite stock with just bolt-ons for now. I've been compiling a list of aftermarket and OEM parts that were used on the build. Not everything is 100% needed, but I decided to dump a ton into this car. Everything that I searched for and replaced can be found on the list. Really just wanting to give back to the forum community from which I've gained knowledge from. Please enjoy and mark-up any thing I missed or you know is specific to other engines. Glad to help anyone going through a KSWAP right now! Rough price including the cost of car, exhaust, wheels and everything needed for the swap ~14k.
HASPORT EGK2 MOUNTS
CRV PASS. SIDE MOUNT (KTUNED MAKES ONE AS WELL FOR K24 OR K20)
-OEM 11910-PPA-000
COOLING/HEATING
IF USING JDM MOTOR, USE A K24 USDM WATER PUMP HOUSING
-MOUNTING HARDWARE
-3 OF THESE 95701-10105-08 (FOUND IT TO BE EASIER THAN STUDS)
-1 OF THESE 10X65 BOLT???? (TOP RIGHT BOLT)
(REPLACE ALL WATER PUMP HOUSING GASKETS AND O-RING)
K24 PARTS (K20 MAY BE THE SAME??)
-WATER PUMP GASKET OEM 19222-RAA-A01
-THERMOSTAT GASKET OEM 19322-PNA-003
-THERMOSTAT SEAL OEM 19305-PNA-003
-WATER PUMP HOUSING O-RING OEM 19322-PCX-003
KTUNED UPPER COOLANT HOUSING (FOR K24 HEAD) (NOT 100% NEEDED)
KTUNED COOLANT ADAPTER (FOR K24 HEAD IF USING K20 INTAKE)
KTUNED COOLANT CAP SOLD SEPARATELY
HYBRID RACING EG KSWAP HALF RAD (DRIVER SIDE) (THIS RADIATOR USES THE ORIGINAL A/C SUPPORTS. DO NOT CUT THOSE OUT!!!)
KTUNED FAN SWITCH (NOT 100% NEEDED IF USING KPRO)
KTUNED D/B SERIES COOLANT SENSOR FOR DASH (NEED ADAPTER IF USING A K20 HEAD)
STILL NEED ECU TEMP SENSOR THATS ON TRANS SIDE OF HEAD
COOLANT HOSES AND CLAMPS
K20 THERMOSTAT HOUSING OR KTUNED SWIVEL NECK
KTUNED HEATER HOSES (IF RUNNING HEATER CORE)
USE KTUNED THERMOSTAT BLOCK OFF PLUG IF NOT RUNNING HEATER CORE
SOLID HEATER PIPE ON FRONT OF ENGINE 19510-RAA-A10, O-RING 91315-PNA-003
TRANSMISSION
6SPD TYPE-S TRANS (LOW FREQUENCY VSS, NO OTHER MODS NEEDED FOR HARNESS)
REPLACE AXLES SEALS ON TRANS
-DRIVER SIDE OEM 91205-PL3-B01
- PASS. SIDE OEM 91206-PHR-003
KTUNED OEM SPEC SHIFT CABLES
KTUNED RACE SPEC SHIFTER
KTUNED SHIFTER PLATE MOUNT ABOVE TUNNEL
KTUNED SHIFTER CABLE STOPS
KTUNED CLUTCH SLAVE CYL AND CLUTCH LINE
INSANE SHAFTS 500 HP
INSANE SHAFTS K20 MANUAL HALF SHAFT (NEEDS TWO INDEXING BOLTS!)
HALF SHAFT MOUNTING HARDWARE
-1 OF THESE 90165-SE0-000
-2 OF THESE 90102-SF1-000
VALEX RACING SELLS AN OEM TRANSMISSION BOLT KIT
NEW ALIGN DOWEL PINS OEM 94301-14200 X2 (BETWEEN ENGINE AND TRANS)
ELECTRONICS
KTUNED CONVERSION HARNESS FOR EG
KTUNED ENGINE HARNESS WIRED FOR K20, WILL NEED TO SWAP FOLLOWING ITEMS...
-CRANK POSITION SENSOR (REPIN A K24 PLUG OR USE A K20 SENSOR)
-YOU CAN SWITCH TO A K20 KNOCK SENSOR OR.. (KTUNED SUPPLIES A K24 PLUG TO REPLACE THE K20, K24 KNOCK SENSOR IS BUILT STRONGER)
KTUNED TPS SENSOR
KTUNED MAP SENSOR
KTUNED AIR TEMP SENSOR
HYBRID RACING PPA,PND, PNF ECU KPRO OPTION
IF USING JDM MOTOR, NEED TO USE USDM ALTERNATOR AND VTEC ASSEMBLY
-ALTERNATOR MOUNTING HARDWARE
-1 OF THESE 90025-PNA-000
-2 OF THESE 95701-08045-08
ENGINE
OEM CAM CHAIN TENSIONER 14510-PRB-A01
EXEDY CLUTCH, PRESSURE AND FLYWHEEL OE EQUIVALANT
MANUAL TRANS OEM FLYWHEEL BOLTS 90011-PNA-B00
OEM PRESSURE PLATE BOLTS 90034-689-000
DON'T FORGET THE RING THAT FITS INSIDE THE CRANKSHAFT THAT HOLDS THE END OF THE MAIN OUTPUT SHAFT OF THE TRANS
SKUNK2 ULTRA STREET K20 INTAKE MANIFOLD, GASKET
KTUNED 72MM THROTTLE BODY, GASKET
KTUNED RAM HEADER, GASKET
KTUNED CENTER FEED FUEL (GET THE KTUNED FPR MOUNTING BRACKET)
KTUNED ADJUSTABLE EP3 PULLEY KIT (PULLEY COMES WITH MOUNT HARDWARE) (ADD AUTOTENSIONER IF NEEDED OEM)
-TENSIONER MOUNTING HARDWARE OEM
-1 OF THESE 95701-08070-08
kennyword1
Mar 23, 2020 06:25 PM
heel_touge
Sep 5, 2013 12:45 PM
tekstyle
Aug 19, 2009 12:32 PM
JDMH22HATCH
Jan 15, 2009 02:19 PM
EGRhatch
Jul 6, 2003 06:30 AM
