Bent Connecting Rod Bolt??
Old Aug 23, 2021 | 04:51 AM
kagami's Avatar
Default Bent Connecting Rod Bolt??
One of my rod bolts has decided it wouldn't like to cooperate. I don't reckon I'll have any luck getting a replacement at the local hardware store. I really do not like this car enough to justify $60 on ARP connecting rod bolts, +the money to get the rods reshaped.
Is there a normal set of bolts I can buy? A single oem replacement bolt? Can I swing by the dealer and ask them to order me one? What are people doing in lieu of the hefty investment in ARP?
Old Aug 23, 2021 | 06:07 AM
NukeNinja's Avatar
Default Re: Bent Connecting Rod Bolt??
They are $6 on ebay shipped. You will spend that much at a hardware store.
Curious: what ITH happened to the engine that was catastrophic enough to bend a con rod bolt, and yet left the rest of the engine valuable enough to not want to spend 60 bucks on it?
Old Aug 23, 2021 | 06:22 AM
DaX's Avatar
DaX
Loved
Community Favorite
Which engine or what year/model/trim? A single D16Z6 rod bolt is $4.41 from Majestic Honda.
Old Aug 23, 2021 | 07:07 AM
kagami's Avatar
The bearing was a bit iffy, but I don't believe the bolt bent until I was reassembling. It was the second piston I dropped in, went to rotate the crank & **** was froze tight. I'm pretty sure I bent it, in short.
It's a D15B2 that was swapped into a 92 hatch - I don't care for the motor because I have an engine on a shelf I want to be building for it. My plan was to get this train wreck operational & putz around in it while I built my "racecar" motor, but it's turned into a bit of a money pit.
Munafo24
Jan 8, 2020 10:04 PM
cmwalker
24
Jun 3, 2012 05:39 AM
tommyj
Apr 22, 2007 02:16 PM
import810
Aug 7, 2006 07:48 PM
visionsOFmadness
Dec 28, 2005 03:22 PM
