B16A 1st gen parts for refresh
Old Aug 22, 2021 | 06:52 AM
neutronscott's Avatar
Default B16A 1st gen parts for refresh
I recently got this 88 CRX with coolant issues: 88 Civic CRX intro
Figured I need to replace the water pump which means little care was done to the engine before it was put in. So I'd like to try this: B16A refresh - Functiontheory
The parts look a bit different from the typical parts list here: b16 parts list
I believe the engine in this article is the 2nd gen so the question is how many parts fit the 1st? Where are the differences? Here's the parts I can see on the table:
Timing belt *14400-P2T-004 94 del sol
Water pump *19200-P72-013 96-01 integra gs-r $113
Oil pump *15100-PR4-A03 90-91 integra $202
Tensioner/spring *14510-P30-003 94 del sol
Spring, Timing Belt Adj *14516-P2T-000 99 civic si $5
Spark plugs *98079-56A7S 94 del sol Spark Plug (PFR6L-13) (Ngk)
Gasket Set, Head Cover *12030-P30-000 94 del sol $60
Oil pan gasket *11251-P30-004 94 del sol
Vtec solenoid gasket *36172-P08-015 95 del sol $9 Gasket, Solenoid Base
O-Rings (?) *91308-P3R-T01
O-Rings (29x2.5) *91324-PR3-003 94 del sol $2 VTEC breather chamber
WindyIce
17
Nov 16, 2015 05:42 AM
nick91civicsi
Oct 23, 2003 07:57 PM
SeaBass
May 31, 2003 03:48 PM
misfithamster
May 17, 2003 07:39 PM
ICeDoUt
Apr 21, 2003 01:31 PM
