Whistling sound around TB as engine shut off
Old Aug 18, 2021 | 04:56 AM
civic9622's Avatar
Default Whistling sound around TB as engine shut off
Hey guys
recently i have a problem with this whistling sound after i switch off my car and it goes like a whistling spiral sound .
I was suspecting it was the aftermarket Air inlet/Box because this sound occurs only after changing an Aftermarket Air Inlet/Box
So, i removed the air inlet so left only the Throttle Body itself and i do the same thing start and turn off the car and the whistling sound is still there
Btw my idling is perfect and it doesnt fluctuate everything seems to be fine and car is running good.
i am just wondering is there a fix to it
i attached a video so u guys can understand
File Type: mov
Old Aug 18, 2021 | 10:04 AM
Stock95delsol's Avatar
Default Re: Whistling sound around TB as engine shut off
Sounds like a vacuum leak. check your hoses and PVC.
Old Aug 18, 2021 | 09:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Put the stock airbox back on and see if the sound still occurs when you shut the car off.
Old Aug 20, 2021 | 11:40 PM
civic9622's Avatar
i have already check my pvc is new and vaccuum hoses theres no leaking
civic9622
Aug 22, 2021 09:17 AM
braass91
Transmission & Drivetrain
Mar 1, 2021 08:10 AM
wesk18
Jan 27, 2009 04:51 PM
Navy_CRX
Jan 21, 2009 11:21 PM
niceprelude
Dec 19, 2008 10:14 PM
