Honda CR-V & Element 2WD & 4WD Element & CR-V
Driver's door won't unlock using switch on 2004 Honda CRV
Old Aug 18, 2021 | 04:30 AM
Rabelraz's Avatar
Default Driver's door won't unlock using switch on 2004 Honda CRV
The lock/unlock switch (35380-S5A-A11ZA) for the driver's door will lock all doors but not unlock any.
The key fob DOES lock/unlock all doors including the driver's door.
The passenger side lock/unlock switch DOES unlock the Driver's side door.
This tells me the command to unlock makes it to the driver side from both routes above and assumed it was the switch itself and bought a new switch but the new switch has the same issue, it will NOT unlock the driver door.
Anyone know how to resolve this issue or can educate me on why the passenger switch and key fob work but the driver switch doesn't because of a different electrical path that it is taking? I have not removed the driver door panel to inspect or connected a multimeter to the driver switch.
Thanks for your time.
Chris
Old Aug 22, 2021 | 05:39 PM
sf340b's Avatar
5 Year Member
Default Re: Driver's door won't unlock using switch on 2004 Honda CRV
I will offer a suggestion but have not looked at the wiring diagram. I would think it would be in the wire from the switch to the drivers door.
Old Aug 22, 2021 | 11:14 PM
GreenBean's Avatar
Agreed, or the switch itself.
We used to see the little copper ribbons of a contact wear down inside door locks and window switches. You could press the switches slightly sideways and make em work.
I am guessing a break in the wiring to the switch.
Old Aug 23, 2021 | 07:35 AM
Thundaraz's Avatar
Check here also, more than one delta with connection pull back was broken and hard to fix. Easier just re-wire like did and works, either way not fun.
Ron Pucci
Mar 7, 2018 09:42 AM
DC2.KILLA
Mar 21, 2014 09:24 AM
hardrock2401
Dec 21, 2013 06:03 PM
Built B16A
Aug 14, 2004 01:06 PM
