Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
'12 Accord A/C Compressor Not Engaging
Old Aug 15, 2021 | 01:53 PM
DocOne's Avatar
Default '12 Accord A/C Compressor Not Engaging
Hello all,
I can't seem to get my compressor to engage. I've changed out the relay, changed the MG clutch fuse, made sure the freon PSI is greater than minimum, and I don't see any condenser leaks. I can't figure out how to test the harness feeding into the compressor coil since there's two wires and only one output. The whole thing is rubberized and I can't figure out where to check.
Any advice on how to troubleshoot this? I've heard of the pressure switch being another problem but I want to get the compressor to engage first so I can rule it out.
Thank you!
Old Aug 29, 2021 | 09:44 AM
DocOne's Avatar
Default Re: '12 Accord A/C Compressor Not Engaging
For anyone following this post, the compressor did actually fail. A new clutch and clutch coil is needed to rebuild the failed components.
kvalrico
Jun 28, 2022 10:10 AM
Chall6733
Oct 30, 2020 02:48 PM
dsmil
May 30, 2017 09:46 PM
005189
Jul 18, 2011 05:55 AM
M15
48
Jul 22, 2006 10:11 PM
