Honda CR-V & Element 2WD & 4WD Element & CR-V
Rear differential leak
Old Aug 15, 2021 | 04:57 AM
munson1's Avatar
Default Rear differential leak
While changing the differential fluid on my 2013 CRV I noticed the passenger side boot had fluid on it.What normally causes this?I recently had the transmission seal’s done, would this be a bad differential seal? Thank you for your help.
Old Aug 15, 2021 | 07:02 PM
sf340b's Avatar
5 Year Member
Default Re: Rear differential leak
Is that the rear diff? I don't see any where else it could come from other than inside the boot/seal.
I have noticed some loose fluid on the pax side of my FWD 02 CRV and could not really pin it down where it was coming from. I had put new CTRL arms on so thought maybe it was self induced and / or leftover.
Old Aug 16, 2021 | 11:37 AM
starchland's Avatar
Looks more like be cv boot weeping. Clean and monitor
Old Sep 7, 2023 | 07:20 AM
Mvans's Avatar
Did you ever find out what was causing the issue pictured here? The passenger side rear axle on my 2013 crv has this exact same oil/dirt buildup.
Thanks
Old Sep 8, 2023 | 04:59 AM
easy129's Avatar
I had the same issue on my 2004 AWD Element and it was the rear differential seal.
Old Sep 8, 2023 | 05:09 AM
Mvans's Avatar
Good to know. Was the repair expensive if you had it done professionally, and if you did it yourself, what was the level of difficulty? I do most of the maintenance myself, but this would be a new one for me.
Thanks
Old Sep 8, 2023 | 05:24 AM
easy129's Avatar
Hi $359 with a Honda discount coupon. I had it done at DCH Paramus Honda in NJ where I bought the vehicle.
juevi
11
Aug 16, 2015 03:09 PM
adrw1
Apr 18, 2007 11:17 PM
DJ0820
Apr 28, 2004 11:12 AM
Toooloud
Acura TL, RL & ZDX
Oct 14, 2002 03:29 AM
