Good evening,
I had blown head, took it to someone to have it fixed, appears to have gone an ok job on the head but I’ve had to fix other stuff since I received the car back.
One being sometimes it idles way high, the idle control valve is in a hard to reach spot but I’m thinking I need to take all of that off and clean it but I think there are hidden hoses behind it that’s hard to get to.
But after fixing another problem which I think ended up being the fan electrical connects we’re dirty because the car was running hot due to the fans not coming on. Sprayed them down with QD Electronic Cleaner and they seem to be working well. I let the car run for about an hour just to make sure it didn’t run hot and it didn’t.
But what did happen was it was running oil pretty bad from somewhere. I was idling at about 2.5 -2.9 which is high the whole time. It was too hot to look under it yesterday so I did today. Attached are pics of the residual oil spill to show how much came out as well as two electrical components that I’m hoping someone will be able to tell me what they are and what they connect to.
thank you in advance. Pic below shows that piece unplugged Unplugged. Prior pic shows where it was unplugged from
