Does a new A/C compressor come with enough oil for a virgin A/C system?
Old Aug 12, 2021 | 04:07 PM
fryman's Avatar
Icon5 Does a new A/C compressor come with enough oil for a virgin A/C system?
Car is a 92 Civic and I'm replacing the entire AC system. The following R134a 95 Civic parts will be installed brand new: evaporator, condenser, expansion valve, rubber compressor hoses, filter/drier, schrader valves, all green o-rings, binary switch, and compressor.. The only oem parts I'll be using are aluminum hard lines from an R134A 95 Civic, I'll also be flushing these lines before install. The compressor I'm installing is a Denso 471-7050 and it says it comes with oil. I understand that when an AC component is replaced you have to add a certain amount of oil to that part to replace the amount that was in it. I also understand that new compressors, that are filled with oil, must have the oil drained and refilled to the amount that the old compressor had in it. My question is; will the new filled AC compressor come with enough oil for the entire system or will the new dry components have to be filled individually? I also don't have the old compressor to measure what oil was in it.
Here are the oil capacities for replacement ac parts, if this info helps:
Total system capacity: 4 - 4.66 oz
Evaporator: 1.66 oz
Condenser: 0.66 oz
Hose line: 0.33 oz
Receiver Drier: 0.33 oz
Old Aug 23, 2021 | 09:22 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Does a new A/C compressor come with enough oil for a virgin A/C system?
Generally, no. Its not filled to the entire system capacity.
Follow your guide there and put the proper amount in each item.
Do not over do it or you risk reduced cooling performance and possible hydro lock.
triple beam
15
Jun 2, 2020 06:50 PM
cliffbrown
May 3, 2018 12:33 AM
SW20FL
Jun 25, 2015 04:47 AM
JohnnyEF
Jul 28, 2009 08:02 AM
Master23
Jun 23, 2009 05:32 PM
