Electrical/ charging issues
Old Aug 11, 2021 | 03:20 AM
BonsaiRay's Avatar
Default Electrical/ charging issues
1995 Honda Accord LX 2.2. Recently had to do an alternator replacement. Due to an AC compressor partially seizing up, a second alternator was needed. Car ran fine for several weeks. Now on my way home from work, lights go dim, tach and Speedo stop working, have to start off in low gear and clicking under glovebox. Strange thing, battery light did not come on at all. Also, when last checked, alternator was producing 14.6 volts when running and only slightly less with car off.
I checked voltage before a hooked up the battery charger and I’m reading 10 volts. In addition, when I got home and turned off the ignition, car would not restart due to extremely low voltage. This is my only means of transportation and is becoming a total nightmare.
Old Aug 14, 2021 | 05:24 AM
Raf99's Avatar
Default Re: Electrical/ charging issues
Ya.. so either the belt is loose, or a loose connection in wiring on the battery. Is the battery grounded properly?
There's also a voltage regulator which may have failed but doubt it (think it's in the ALT).
BonsaiRay
Jul 24, 2021 05:31 PM
mistakesmade
Honda Civic (2001 - 2005)
Jul 31, 2018 10:33 PM
katieboberts
Jun 15, 2018 01:14 PM
shawndb1
Apr 4, 2009 09:10 AM
TypeS12
Apr 2, 2003 11:59 PM
