2013 CRV A/C High/low Pressure
Last week I took a long drive and noticed 45 minutes into my trip that Mist was coming out of my vents, after I smelled chemicals so I shut the ac off an found an automotive store and put in some refrigerant,Afterward I never smelled or seen the vapor again.I never changed my cabin filter(8 years) till today. I picked up a set of gauges to check both the high and low side.Compressor turns on for 9 seconds and turns off for 4 seconds.I found an Acura A/C chart for high-low and it seems like my numbers are off.Does anyone have a chart For CRV?
74 degrees(75 degree chart)
Humidity 80
Suggested reading
Low. High. Temp. Cabin
25-37. 84-155. 43 degrees output
Actual Reading
26-40. 150-170 43/46degrees
My low reading of 26 is compressor on and 40 is compressor off.For high it’s 170 compressor on(then drops) and 150 compressor off.
While the compressor is running the high hits 170 and starts dropping before the compressor shuts off.Is This normal?
Static reading
H—L
84 85
I’m going to clean the condenser with some coil cleaner.
Do I have a defective Drier packet?or expansion valve?or do these numbers look normal?
Thank you for helping me out!!!
Humidity 80
Suggested reading
Actual Reading
Static reading
H—L
84 85
Normal
You only check pressures while the compressor is running and after the temperatures in the system have stabilized.
The mist in the cabin is normal under certain weather conditions, mostly high humidity. It is the ice on the evaporator melting off.
Suggested reading
Low. High. Temp Cabin
27-42. 128-181. 52.Degrees
Actual
29-40. 175-195 46 Degrees
82Degrees
So the Low side with the compressor engaged is 29PSI and the high side with compressor engaged and high settling is 195 @Idle .I’m not sure if Acura would be “Accurate” for CRV ..pun intended but the high side is slightly over the limits.Is this anything to worry about?
Idle will see higher than normal high side pressure with the limited air flow over the condenser.
If you are not having cooling issues (is suspect you are bot with those numbers) then send it.
redman8741
Aug 2, 2018 04:22 AM
arielb1
Jul 15, 2017 04:43 PM
RFEwing
Aug 15, 2016 10:20 AM
