Need a starting point on diagnosing wiring issues (DPFi Mpfi)
Old Aug 4, 2021 | 01:52 PM
Spaceturtle917's Avatar
Default Need a starting point on diagnosing wiring issues (DPFi Mpfi)
Long story, complicated issue, hoping for some insight.
Buddy of mine has a 90 HF CRX. It has a zc swap that had some pretty bad wiring for the dpfi to mpfi conversion. So we bought this harness DPFI to MPFI to hopefully clean up the wiring. The harness fits and works and we followed the simple pinning instructions. But at the same time we installed an OBD2a Dizzy off of a crv and used and OBD0 - OBD1 conversion harness to run a chipped p28. The ecu works and is tested in my car. I did the dizzy wiring perfect and I have full confidence in that.
The car does not start. No fuel, no spark, fuel pump does not prime.
Tomorrow I'm going to try to work backwards on the documented steps of doing a dpfi to mpfi conversion as the harness we bought should cover most of that.
What are things I could test and look into for diagnosing this problem?
Old Aug 4, 2021 | 02:26 PM
jlicrx's Avatar
Default Re: Need a starting point on diagnosing wiring issues (DPFi Mpfi)
don't understand - CRX HF was not DPFI - it was MPFI - are you sure the car was HF? - sounds like not? - HF engine harness is not the same as Si engine harness, although they are both MPFI - the harnesses are not interchangeable
Old Aug 4, 2021 | 02:38 PM
It's an HF (maybe not), car was clearly converted to mpfi, pretty poorly at that. And then we bought the mpfi conversion harness to do it properly and now it's giving us issues. I know the whole thing is complicated.
Old Aug 5, 2021 | 05:43 AM
TacoCat's Avatar
5 Year Member
The starting system is independent from the ECU so the engine will turn over even if the ECU isn't in the car. The fuel pump, ECU and injectors are powered by the main relay. A12 and A14 ECU pins provide a ground to the fuel pump side of the relay and A2 and A4 provide the ground signal for the injector relay and ECU. Power comes into the ECU from the main relay on A13 and A15.
Based on your description, I doubt the problem is under the hood. I would test the main relay along with the wires between it, the ECU and power coming from the ignition switch. Get the CRX workshop manual and look at the diagram on page 6-13. Also check all the grounds.
Old Aug 5, 2021 | 05:52 AM
Yes main relay seems to be the issue, I already tested a15 for power and got nothing.
AH419
Jul 13, 2012 09:57 AM
lilchris813
Jan 27, 2012 10:43 AM
sliiiiced
Jul 7, 2010 07:50 PM
Heavy Pee
Oct 13, 2002 11:44 PM
Leisyman
Mar 31, 2002 07:33 AM
