Wtf is causing this?
Old Aug 4, 2021 | 11:58 AM
LilCletus's Avatar
Default Wtf is causing this?
I put a obd0 SOHC ZC engine with L3 trans in a 1991 CRX Si that was fully stock beforehand. Drove perfectly before, but the engine died. Now the new engine is sitting too far to the right it seems and keeps destroying the driver side inner CV joint. Mounts are new and the engine is pushed as far left as I can get it.
Pass. Side CV looks compressed
Drivers side CV inner joint boot all twisted up and about to break. Again. After pulling out of the driveway and driving like 5 feet.
Is there a longer axle I can use? Im out of ideas, please help.
Old Aug 5, 2021 | 06:30 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Wtf is causing this?
I can't recall 100%, but I think you need to use the post mount from your A6 on the ZC engine.
Old Aug 11, 2021 | 02:36 PM
LilCletus's Avatar
Pulled this bracket stamped E3 off the old engine, and see
D1 stamped on the new. Is there any difference before I start tearing it up?
They look the damn same. So does the plastic timing cover
Old Aug 11, 2021 | 06:01 PM
scelestus's Avatar
Originally Posted by LilCletus
E3
D1
There is a place, known to some as Harbor Freight. In this place you may obtain a device, known as a digital caliper. It is (last I checked) 7.99 plus applicable tax. It will help you divine if these are the same.
Otherwise, perhaps you can find someone from the OEM supplier who knows what the casting marks indicate.
LilCletus
Jul 30, 2021 08:41 AM
tonekids
Feb 19, 2013 08:44 AM
greyEG
Suspension & Brakes
Jan 12, 2012 07:05 PM
smapty
Aug 29, 2005 10:31 AM
