Transmission & Drivetrain Gearboxes, Differentials, Clutches
Both axles stuck and spinning the same way
Old Aug 3, 2021 | 12:27 PM
David Popoff's Avatar
Default Both axles stuck and spinning the same way
Put my trans back on last night, realized I put the throwout bearing and clutch fork assembly back together wrong. Went to take the axles back out and both of them are stuck stuck inside the transmission and spinning the same way while in neutral.
Old Aug 3, 2021 | 07:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Both axles stuck and spinning the same way
Axles being stuck has nothing to do with the incorrect installation of the clutch fork and release bearing. Something else is wrong. What brand of axles do you have ?
Old Aug 3, 2021 | 09:05 PM
Yeah I know they are separate issues. ill double check the brand, but they were slipping in and out no problem before.
ALL IMPORT
Feb 20, 2008 04:35 PM
adobospoon
Oct 17, 2007 10:12 AM
smoovekriminal
Sep 25, 2007 07:50 PM
HybridMT
Nov 1, 2001 09:05 AM
