Identify weird plastic strip with Mugen style spoiler
Old Aug 2, 2021 | 09:23 AM
slowresto's Avatar
Default Identify weird plastic strip with Mugen style spoiler
Ordered a Mugen style wing and it came with these plastic strips. Anyone have any idea on what I should do with them. Car is a 2000 LX sedan.
Old Aug 2, 2021 | 11:26 AM
tony_2018's Avatar
Fish Twig
Default Re: Identify weird plastic strip with Mugen style spoiler
You take a look at the wing to see if it goes somewhere?
Old Aug 2, 2021 | 11:36 AM
slowresto's Avatar
Havent installed it yet, but I tried to figure it out like a puzzle but I dont know.
Old Aug 2, 2021 | 02:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Those look like drilling locator tabs. You simply insert one into each hole on the bottom of the wing with the tabs perpendicular with the wing edge... so that once you have the wing on the trunk lid in the appropriate place, you can tape down both ends of the tab to the trunk lid or body. Then you carefully remove the wing so that you do not disturb the placement of these tabs. Then you can drill through the opening in the middle of the part that is sticking up (previously installed in the threaded holes of the under side of the wing) with a small drill bit to make a pilot hole. Once all holes are drilled, you can remove them and increase the size of the holes to the necessary size of the threaded holes in the wing.
Last edited by JRCivic1; Aug 3, 2021 at 06:58 PM. Reason: Misspelled a word... didn't proof read.
Old Aug 3, 2021 | 04:32 AM
slowresto's Avatar
Originally Posted by JRCivic1
Those look like drilling locator tabs. You simply insert one into each hole on the bottom of the wing with the tabs perpendicular with the wing edge... so that once you have the wing on the trunk lid in the appropriate place, you can tape down both ends of the tab to the trunk lid or body. Then you carefully remove the wing so that you do not disturb the placement of these tabs. Then you can drill through the opening in the middle of the part that is sticking up (previously installed in the threaded holes of the under side of the wing) with a small drill bit to make a pilot hole. Once all holes are drilled, you can remove them and increase the side of the holes to the necessary size of the threaded holes in the wing.
Thanks for your response. Very helpful.
Old Aug 3, 2021 | 09:32 AM
tony_2018's Avatar
Fish Twig
They don't have instructions included?
Old Aug 4, 2021 | 03:58 AM
slowresto's Avatar
none, but I emailed the company and they confirmed what jr1cvic said.
JDMCrx1991
Nov 9, 2010 03:17 PM
Sifu
Jun 1, 2005 09:48 PM
Rwecked
Nov 2, 2002 10:57 PM
