Steering wheel with airbag (SRS)
Hello all,
i have a EUDM integra type r (Import from Italy), i don't have a lot of space with the current SRS steering wheel (I'm tall and my knee hits the steering wheel when trying to heel/toe).
A lower seat frame is installed and it's still not that good.
Is there a way or a mods to adjust the steering wheel a bit closer to me ?
Or replace the steering wheel with an aftermarket one (With airbag) or replace with a steering wheel from another Honda/Acura models?
I haven't found any aftermarket steering wheel with airbag and until i have a rollcage installed with harness i don't want to remove the airbag since i still daily drive this car quite often.
Thank you for your help,
older hondas have a smaller steering wheel but no air bag. im assuming airbag is required for your local inspection?
only option i can think of is a custom steering column to extend steering towards driver.
Thank you for your response,
Yes airbag is needed where I live (France)
I end up on this site : https://www.spacershop.com/?product=...or-honda-s2000
After talking to them, they said that i can use the spacer for s2000, it should be compatible with the itr dc2 oem steering wheel.
I need to dig a a little to check if the steering column are really the same
Hello,
Yes that's wht i've found, so i guess the spacer won't fit because the holes on the steering column are not the same :/
Unfortunately after looking almost every thread on this, there's no solution except using aftermarket steering wheel or getting a low bucket seat.
I guess I will put an aftermarket steering wheel when i will have the rollcage install.
i just gave you a solution. swap steering column to ek and use s2000 wheel with the spacer.
deff not cheaper than going aftermarket....and as you said, you are restricted due to location.
denward
Apr 4, 2020 01:58 PM
$amGD3
Feb 25, 2006 08:04 PM
