Aftermarket rear lower tie bar type r?
Old Jul 30, 2021 | 08:19 PM
NYdc2typer.'s Avatar
Default Aftermarket rear lower tie bar type r?
I have a jdm spec rhd type r i imported to the states. I just bought coilovers and rear lower control arms. I noticed the oem lower tie bar is not in great shape. Do they make an aftermarket lower tie bar for the integra type r. I keep finding ones for ls gs models. Thank you
Old Sep 2, 2021 | 02:13 PM
Mt3c's Avatar
Default Re: Aftermarket rear lower tie bar type r?
Comptech use to make one, but super rare to find now and they have been out of business for years. I’m not sure if I’m fully correct, but HeelToe picked up there IP and can reproduce them?
im searching for one also
Old Sep 3, 2021 | 03:56 PM
Klasse's Avatar
Like this?
https://www.speedscience.co.nz/produ...-tie-bar-eg-dc
Old Sep 7, 2021 | 01:13 PM
Originally Posted by Klasse
It does not seem to specify for type r. The bracket on each end would not be needed on a type r. However im unsure if the two bolt holes on the bar itself are in the correct locations to match the type r subframe. The geometry does look the same tho.
Old Sep 8, 2021 | 05:58 AM
Mt3c's Avatar
The one you posted bolts to the pivot point of the lca, the type R rear tie bars bolt to the fixed mounting points.
see the red comptech bar
https://www.typerclub.org/forums/vie...t=512&start=10
Old Sep 8, 2021 | 09:53 AM
spAdam's Avatar
Loved
Community Favorite
Heeltoe only picked up the the tooling for the Icebox and the associated rights. The rest of the Comptech stuff is still out to lunch somewhere, unfortunately.
The Collin
Jan 18, 2007 08:27 PM
RobbieG35
Feb 12, 2004 01:29 PM
ckkl
Jan 14, 2003 09:05 PM
The Poopsmith
Oct 23, 2002 05:37 PM
