B16A Swap Motor Mounts
So I have a B16A swapped 1996 EK civic and two of the motor mounts are shot. The vibrations in the car are unreal.
1. What kind of motor mounts should I get (solid vs OEM)? I don't mind a little vibration but this will be a daily driver (30+ mins of driving)
2. Do I get B16 mounts even though the EK had the D16 in it? Does it matter? Do I need to get an adapter bracket?
Thanks
Thanks
The Torque mounts for the '99-00 Si are different from those found on the other 6G Civics... so if torque mounts are what you need to replace, get the ones from a '96-00 Civic EX. The remaining three mounts should be replaced with ones from the '99-00 Civic Si as stated by NukeNinja above.
zerogravitycrx
Aug 25, 2005 09:55 AM
quicksol95
18
May 18, 2004 03:37 PM
